Activation Problems after manual update
After manual update, I had problems with Grub2, some boot failure with SSD, I fix it over centos board tools yum and systemctl, after that I did rm .rockstorinit and start /opt/rockstor/bin/rockstorinit (I think a topic in forum) - GUI is working but not all user accounts can use, nob, but I can not reactivate the installation now.
Is it possible for consols user, describe functions for manual rockstorinit process in docs, I must search some articles in forum and git to build a workaround?
I think this was more then one problems, first boot problems - to kernel panic in each mode, second no update function, its from snort rules, now it is ok, third the yum update doesnt working - an other process lock yum - kill, yum clean, yum update, new 3.9.0 rockstore rpm is loading an other - next step systemctl task to proof which services not running, kdump.service and rockstor.service not working - and start with systemctl, it works fine - after reboot all functions okay, but no activation is possible.
File “/opt/rockstor/src/rockstor/storageadmin/views/update_subscription.py”, line 86, in post
stableo = self._toggle_repos(password=password)
File “/opt/rockstor/src/rockstor/storageadmin/views/update_subscription.py”, line 66, in _toggle_repos
raise Exception(e_msg)
Exception: Activation code(UIuh9hLGPO4RZvgcUaGrHg==) could not be authorized. Verify the code and try again. If the problem persists, contact support@rockstor.com
[paste here]
