So I’m attempting to mount a share in a pure docker image, via this startup script. Essentially it just starts a docker image with mount points to my main file server share:
docker run -d --user $UID:$GID \
-p 8080:8080 -p 6881:6881/tcp -p 6881:6881/udp \
-v /config:/mnt2/Cold/System/QBT \
-v /torrents:/mnt2/Cold/System/QBT/TorrentFiles \
-v /downloads:/mnt2/Cold \
wernight/qbittorrent
And it seems pretty straightforward. I’ve tested this on local directories, and everything works without any kind of issue. But the moment I try and mount something in /mnt2, I can’t see anything in that mount folder from inside the docker container once it’s running. Running a docker inspect on the image gives me this:
"Mounts": [
"Type": "bind",
"Source": "/downloads",
"Destination": "/mnt2/Cold",
"Mode": "",
"RW": true,
"Propagation": ""
"Type": "volume",
"Name": "de2a7a6849c44309c23325ebcda45b3e67e781be5f0b2a07cd64a671b0dbf568",
"Source": "/mnt2/RockOnShare/volumes/de2a7a6849c44309c23325ebcda45b3e67e781be5f0b2a07cd64a671b0dbf568/_data",
"Destination": "/config",
"Driver": "local",
"Mode": "",
"RW": true,
"Propagation": ""
"Type": "volume",
"Name": "8341258874b5281463ec531718db9b5963a9533e5742f753c906476580a96e5f",
"Source": "/mnt2/RockOnShare/volumes/8341258874b5281463ec531718db9b5963a9533e5742f753c906476580a96e5f/_data",
"Destination": "/downloads",
"Driver": "local",
"Mode": "",
"RW": true,
"Propagation": ""
"Type": "volume",
"Name": "a1c0969cf69a83105af117c9d650ab49525a81dc70fff54c6e595fa08b36a661",
"Source": "/mnt2/RockOnShare/volumes/a1c0969cf69a83105af117c9d650ab49525a81dc70fff54c6e595fa08b36a661/_data",
"Destination": "/torrents",
"Driver": "local",
"Mode": "",
"RW": true,
"Propagation": ""
"Type": "bind",
"Source": "/config",
"Destination": "/mnt2/Cold/System/QBT",
"Mode": "",
"RW": true,
"Propagation": ""
"Type": "bind",
"Source": "/torrents",
"Destination": "/mnt2/Cold/System/QBT/TorrentFiles",
"Mode": "",
"RW": true,
"Propagation": ""
It’s the strangest thing, and I don’t know where these extra volumes are coming from. Anyone know what I’m doing wrong, and is there anything extra required for a docker image to access a share? I’ve tried darn near everything and I’m at a loss at what to do next.
