Check 'Writes' by default when refreshing Dashboard
I set my Dashboard to refresh every 5 minutes, so as to keep the session from expiring & so I’ll have current values displayed all the time.
But even if I manually check the ‘Writes’ box in the Disks section, it always reverts to it being unchecked. Is there a config file I can edit so that it stays checked?
Thanks,
-w
Hello,
Thanks for reporting the issue. I am able to reproduce it. I have opened an issue for this. Will work on it.
Thanks,
Priyanka
