maxhq
(Maxhq)
January 4, 2017, 12:15am
1
NetworkManager causes some of warnings and errors in my specific installation, so I’d like to completely disable it.
Now I wonder: does Rockstor (and Rockons/Docker) work without NetworkManager?
phillxnet
(Philip Guyton)
January 4, 2017, 12:08pm
2
@maxhq Hello again.
It looks like Rockstor uses the command line networkmanager tools to do it’s network stuff, ie “nmcli”:
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
import json
import logging
import re
from .exceptions import CommandException
from .osi import run_command
NMCLI = '/usr/bin/nmcli'
DEFAULT_MTU = 1500
logger = logging.getLogger(__name__)
def val(s):
fields = s.split(': ')
if (len(fields) < 2):
Maybe you’ve found another bug?
