hello, i’m exploring this feature and have kind of a doubt. i want to reorganize shares in rs so decided to clone one share. once done, i can see in the file explorer all folders and files, but from the shares panel i can see
The answer is, funnily enough, both: at least initially anyway.
A ‘Clone’ in Rockstor parlance is just a ‘special case’ writable (rw) btrfs snapshot. The special case is just it’s path: ie top level. That is why initially it takes no additional space as if no files are changed, in relation to it’s parent, then no additional space is required to represent the same files. However as the parent or the clone (child snapshot) change from one another (ie differ), additional space is required to represent the differing information they then reference.
You can see the relationship via the command line in the following example:
we create a rock-share (in rock-pool) and then clone it:
btrfs subvolume show /mnt2/rock-pool/rock-share
rock-share
UUID: 59132e14-d486-dc42-bbe1-7ca5d266194a
Parent UUID: -
Received UUID: -
Creation time: 2018-06-05 11:17:35 +0100
Subvolume ID: 340
Generation: 241
Gen at creation: 240
Parent ID: 5
Top level ID: 5
Flags: -
Snapshot(s):
rock-share-clone
and the same command for the clone:
btrfs subvolume show /mnt2/rock-pool/rock-share-clone/
rock-share-clone
UUID: 9defbc90-7931-294c-84c2-af7d762306fd
Parent UUID: 59132e14-d486-dc42-bbe1-7ca5d266194a
Received UUID: -
Creation time: 2018-06-05 11:17:50 +0100
Subvolume ID: 341
Generation: 241
Gen at creation: 241
Parent ID: 5
Top level ID: 5
Flags: -
Snapshot(s):
which doesn’t yet have any snapshots of it’s own, but could have.
Note the “Parent UUID” entries in both of the above.
But given their unique subvolume ID’s they are independent file systems, within the scope of the Pool, or Volume in btrfs speak.
