Trying to adjust Raid from 5 to 6 and add 4 drives to the existing 6 drives. Using the online gui.
Error running a command. cmd = /sbin/btrfs device add /dev/disk/by-id/ata-Hitachi_HUA722020ALA331_YBKJELBD /dev/disk/by-id/ata-Hitachi_HUA723020ALA641_YFGJA1YA /dev/disk/by-id/ata-Hitachi_HUA723020ALA641_YFHVLEHA /dev/disk/by-id/ata-Hitachi_HUA723020ALA641_YGGPHY9A /mnt2/maindata. rc = 1. stdout = ['']. stderr = ['/dev/disk/by-id/ata-Hitachi_HUA722020ALA331_YBKJELBD appears to contain a partition table (gpt).', 'ERROR: use the -f option to force overwrite of /dev/disk/by-id/ata-Hitachi_HUA722020ALA331_YBKJELBD', '/dev/disk/by-id/ata-Hitachi_HUA723020ALA641_YFGJA1YA appears to contain a partition table (gpt).', 'ERROR: use the -f option to force overwrite of /dev/disk/by-id/ata-Hitachi_HUA723020ALA641_YFGJA1YA', '/dev/disk/by-id/ata-Hitachi_HUA723020ALA641_YFHVLEHA appears to contain a partition table (PMBR).', 'ERROR: use the -f option to force overwrite of /dev/disk/by-id/ata-Hitachi_HUA723020ALA641_YFHVLEHA', '/dev/disk/by-id/ata-Hitachi_HUA723020ALA641_YGGPHY9A appears to contain a partition table (gpt).', 'ERROR: use the -f option to force overwrite of /dev/disk/by-id/ata-Hitachi_HUA723020ALA641_YGGPHY9A', '']
File "/opt/rockstor/src/rockstor/storageadmin/views/pool.py", line 406, in put
resize_pool(pool, dnames)
File "/opt/rockstor/src/rockstor/fs/btrfs.py", line 209, in resize_pool
return run_command(resize_cmd)
CommandException: Error running a command. cmd = /sbin/btrfs device add /dev/disk/by-id/ata-Hitachi_HUA722020ALA331_YBKJELBD /dev/disk/by-id/ata-Hitachi_HUA723020ALA641_YFGJA1YA /dev/disk/by-id/ata-Hitachi_HUA723020ALA641_YFHVLEHA /dev/disk/by-id/ata-Hitachi_HUA723020ALA641_YGGPHY9A /mnt2/maindata. rc = 1. stdout = ['']. stderr = ['/dev/disk/by-id/ata-Hitachi_HUA722020ALA331_YBKJELBD appears to contain a partition table (gpt).', 'ERROR: use the -f option to force overwrite of /dev/disk/by-id/ata-Hitachi_HUA722020ALA331_YBKJELBD', '/dev/disk/by-id/ata-Hitachi_HUA723020ALA641_YFGJA1YA appears to contain a partition table (gpt).', 'ERROR: use the -f option to force overwrite of /dev/disk/by-id/ata-Hitachi_HUA723020ALA641_YFGJA1YA', '/dev/disk/by-id/ata-Hitachi_HUA723020ALA641_YFHVLEHA appears to contain a partition table (PMBR).', 'ERROR: use the -f option to force overwrite of /dev/disk/by-id/ata-Hitachi_HUA723020ALA641_YFHVLEHA', '/dev/disk/by-id/ata-Hitachi_HUA723020ALA641_YGGPHY9A appears to contain a partition table (gpt).', 'ERROR: use the -f option to force overwrite of /dev/disk/by-id/ata-Hitachi_HUA723020ALA641_YGGPHY9A', '']
