[write here]
Unfortunately, we do not have much to start helping you here… Would you be able to provide more information as listed in the template you used? Mainly, we would need to know:
If you’re encountering an issue during the first installation process, could you provide more information on:
you system: physical or virtual machine? How many drives (and what type) were connected? (note that I usually prefer to connect only the drive that will receive the OS during install to simplify things. You can plug all the data drives later on)
the step at which you encountered the error?
Yeah, this can be quite tricky… Sometimes people take a picture of the screen, that can always be helpful.
