I’m trying to migrate to Rockstor 4.1 (OpenSuse). That’s not working (freezing during install on HP Proliant Microserver N54L AMD Turion), and including nomodeset
kernel option has not made any difference.
Before prodding around some more (and no doubt needing help for that) I thought I’d reinstate the previous install.
This hasn’t worked.
The system boots up and sees the data discs (but SMART is not supported - I believe it used to be), but the pool is not mounted. The shares are visible but empty. (Of course if I could get the pool mounted in the V4.1 system, this wouldn’t be a problem.)
- Attempt to install Rockstor V4.1 (with data discs unplugged)
- Give up after several attempts to install e.g. ctrl+alt+del before prompt for select locale
- Revert to previous boot disc 3.9.1-16
- System fails to see pool - discs are there but the pool fails to mount.
Note: although the data discs were unplugged before any attempt to install, they were plugged in when booting into a version of grub
which did not enter the installer i.e. found nothing for grub
to pass control to.
File "/opt/rockstor/src/rockstor/storageadmin/views/pool_balance.py", line 47, in get_queryset
self._balance_status(pool)
return func(*args, **kwargs)
File "/opt/rockstor/src/rockstor/storageadmin/views/pool_balance.py", line 72, in _balance_status
cur_status = balance_status(pool)
File "/opt/rockstor/src/rockstor/fs/btrfs.py", line 1064, in balance_status
mnt_pt = mount_root(pool)
File "/opt/rockstor/src/rockstor/fs/btrfs.py", line 283, in mount_root
'Command used %s' % (pool.name, mnt_cmd))
Exception: Failed to mount Pool(fullPool) due to an unknown reason. Command used ['/bin/mount', u'/dev/disk/by-label/fullPool', u'/mnt2/fullPool']
