Hi all,
I’ve been following Rockstor for a few months now and really like where it’s headed so I used it for a new home server a few days ago. On a fresh install of the latest stable release, I created two shares for export via Samba. These were originally set up as Read-only access but I changed my mind and edited the shares to allow write access. Although the shares status showed the change, I was never able to actually get write permission when trying through file explorer.
I turned off/on Samba sharing to see if it would enable the write access (this proved to be a terrible idea) and almost immediately got an error message in the Web UI, first on the Samba page and then quickly cascading to every page. I used the Web UI to do a reboot of the machine, which was successful and I can log in from the command prompt, but the Web UI now will only show the Rockstor header with “Page Not Found - Sorry, an unexpected internal error has occured.” I can also still access the shares through file explorer though, although the read-only permission has still not changed.
Installation went smoothly, as did adding Rockons for Plex and OwnCloud with separate shares for each, but my Linux experience is just a hair north of zero at this point so, short of reinstalling everything again, I don’t have many ideas of where to even start on fixing this. I’ve downloaded the error log files, both from the original Samba page error and the Web UI login page error, if someone can please point me in the direction of pulling out useful information for resolving this.
I have two, 3TB drives set up in Raid 1 with Rockstor installed on a separate SSD/PCI combo I bought through the Rockstor shop.
Any help or ideas would be appreciated.
Geoff
