I have configured rockstor and enabled NTP. When trying to enable The active directory service i add the AD details however the service fails to work, below is the error received.
> Traceback (most recent call last):
> File "/opt/rockstor/src/rockstor/rest_framework_custom/generic_view.py", line 41, in _handle_exception
> yield
> File "/opt/rockstor/src/rockstor/smart_manager/views/active_directory.py", line 199, in post
> smb_config = self._get_config(smbo)
> File "/opt/rockstor/src/rockstor/smart_manager/views/base_service.py", line 40, in _get_config
> return json.loads(service.config)
> File "/usr/lib64/python2.7/json/__init__.py", line 338, in loads
> return _default_decoder.decode(s)
> File "/usr/lib64/python2.7/json/decoder.py", line 366, in decode
> obj, end = self.raw_decode(s, idx=_w(s, 0).end())
> TypeError: expected string or buffer
Can anyone advise what may be causing this issue?
Thanks in advance.
