RAID controller failed, so disk went away. Unrecoverable. Can’t remove exports, shares, pool, disk from Rockstor, as it can’t mount the disk. UI disk page shows disk as detached, but no trashcan. Instead the mouseover points to “pool resize” to remove.
Rip disk out from under the OS with configured pool, shares, exports. Attempt to remove the disk.
When using “Resize/ReRaid pool” the following is the result of “remove disk”
File “/opt/rockstor/eggs/gunicorn-19.7.1-py2.7.egg/gunicorn/workers/sync.py”, line 68, in run_for_one
self.accept(listener)
File “/opt/rockstor/eggs/gunicorn-19.7.1-py2.7.egg/gunicorn/workers/sync.py”, line 27, in accept
When trying to step it back starting at exports, then delete share, then pool to clear the disk, the export delete attempt states:
Exception: Failed to mount Pool(SATA_pool) due to an unknown reason.
Is there a way to CLI force the removal of all entries for pool, share and export related to that disk?
