Inability to delete ‘unmounted’ shares
Created replication, however it failed due to network interrupt. Deleted main share ok. Sub share (.snapshot/filename…) refuses to be deleted (force delete no good) and now shows ‘unmounted’ in the status column.
There is no record of this ‘snapshot’ in the snapshots table.
File “/opt/rockstor/src/rockstor/storageadmin/views/share.py”, line 337, in delete
force=force)
File “/opt/rockstor/src/rockstor/fs/btrfs.py”, line 800, in remove_share
toggle_path_rw(subvol_mnt_pt, rw=True)
File “/opt/rockstor/src/rockstor/system/osi.py”, line 546, in toggle_path_rw
return run_command([CHATTR, attr, path])
CommandException: Error running a command. cmd = /usr/bin/chattr -i /mnt2/nas3_pool1/.snapshots/00020003-0004-0005-0006-000700080009_home/home_23_replication_129. rc = 1. stdout = [‘’]. stderr = [‘/usr/bin/chattr: Read-only file system while setting flags on /mnt2/nas3_pool1/.snapshots/00020003-0004-0005-0006-000700080009_home/home_23_replication_129’, ‘’]
Have tried deletion via console as well but just says ‘read only’.
Hoping this isn’t a major problem as to get replication working has been a time consuming thing.
Many thanks
Paul
