Rockstor began disappear from network and required reboot to restart. AFter one reboot it ceased to appear and rockstor will no longer initialize, even manually from the shell. The web-ui is not accessible and this error is produced.
Start rockstor machine
Attempt to run /opt/rockstor/bin/initrock
Unable to access
File "/opt/rockstor/bin/initrock", line 44, in
sys.exit(scripts.initrock.main())
File "/opt/rockstor/src/rockstor/scripts/initrock.py", line 418, in main
run_command([PREP_DB, ])
File "/opt/rockstor/src/rockstor/system/osi.py", line 98, in run_command
system.exceptions.CommandException: Error running a command. cmd = ['/opt/rockstor/bin/prep_db']. rc = 1. stdout = ['']. stderr = ['Traceback (most recent call last):', ' File "/opt/rockstor/bin/prep_db", line 44, in ', ' sys.exit(scripts.prep_db.main())', ' File "/opt/rockstor/src/rockstor/scripts/prep_db.py", line 63, in main', ' create_setup()', ' File "/opt/rockstor/src/rockstor/scripts/prep_db.py", line 57, in create_setup', ' if len(setup) == 0:', ' File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/query.py", line 77, in __len__', ' self._fetch_all()', ' File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/query.py", line 857, in _fetch_all', ' self._result_cache = list(self.iterator())', ' File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/query.py", line 220, in iterator', ' for row in compiler.results_iter():', ' File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/sql/compiler.py", line 713, in results_iter', ' for rows in self.execute_sql(MULTI):', ' File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/sql/compiler.py", line 785, in execute_sql', ' cursor = self.connection.cursor()', ' File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/backends/__init__.py", line 162, in cursor', ' cursor = util.CursorWrapper(self._cursor(), self)', ' File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/backends/__init__.py", line 132, in _cursor', ' self.ensure_connection()', ' File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/backends/__init__.py", line 127, in ensure_connection', ' self.connect()', ' File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/utils.py", line 99, in __exit__', ' six.reraise(dj_exc_type, dj_exc_value, traceback)', ' File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/backends/__init__.py", line 127, in ensure_connection', ' self.connect()', ' File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/backends/__init__.py", line 115, in connect', ' self.connection = self.get_new_connection(conn_params)', ' File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/backends/postgresql_psycopg2/base.py", line 115, in get_new_connection', ' return Database.connect(**conn_params)', ' File "/opt/rockstor/eggs/psycopg2-2.6-py2.7-linux-x86_64.egg/psycopg2/__init__.py", line 164, in connect', ' conn = _connect(dsn, connection_factory=connection_factory, async=async)', 'django.db.utils.OperationalError: could not connect to server: No such file or directory', '\tIs the server running locally and accepting', '\tconnections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?', '', '']
