I noticed when attempting to read files over smb to my btrfs share that the performance was nowhere as fast as expected I began diagnosing the issue and tested the network connection using iperf, averaging about 600 - 700mbs over lan between the client and rockstor. I used a simple dd read and write test and found that the btrfs raid was capped at around 6mb/s write and 4mb/s write on the local machine. I attempted the test again with noatime and thread_pool at 6 with similar results. Compression is not enabled.
All disks pass smart check.
dd results
[root@ecnetraid ~]# time dd if=/dev/zero of=/mnt2/Content2016/test.data bs=4K count=1024000
1024000+0 records in
1024000+0 records out
4194304000 bytes (4.2 GB) copied, 16.2449 s, 258 MB/s
real 0m16.250s
user 0m0.238s
sys 0m7.266s
i must say i am impressed that u can utilize an 10Gigabit connection with 260MByte/s this way…
no. this result CANT be true. u writing to cache. u have to run dd with sync option! also use bigger chunks bigger than the nic speed, like 150M. i use something like 1G in general.
ITs a 1gb lan connection. When the storm is over I can rerun dd to get a result. The fact is that over SMB I am getting nowhere near the read or write speed.
[root@ecnetraid etc]# time dd if=/dev/zero of=/mnt2/Content2016/test.data bs=4K count=1024000; sync
4194304000 bytes (4.2 GB) copied, 15.7782 s, 266 MB/s
real 0m17.174s
user 0m0.201s
sys 0m7.362s
Here is the smb performance
time dd if=/dev/zero of=/Volumes/Content2016/test3.data bs=4k count=1024000; sync
4194304000 bytes transferred in 100.464125 secs (41749271 bytes/sec)
real 1m41.120s
user 0m0.318s
sys 0m14.466s
time dd if=/dev/zero of=./test3.data bs=4k count=1024000; sync
4194304000 bytes transferred in 254.706766 secs (16467187 bytes/sec)
real 4m15.307s
user 0m0.215s
sys 0m15.944s
I’m experiencing slow speed over SMB as well. I have a 6 disk RAID 5 array and I normally can get over 100MBytes/s write speed when copying files from my PC to the fileserver. Now I’m getting 10-15MBytes/s!
Please advise what to do?
