I have just downloaded Rockstor and installed to a USB. When I boot from the USB i am presented with a login prompt. What should I do now ??
The doco that I have seen says that above the login prompt will be a URL that I can use to administer Rockstor accross a network. This does not appear. When logging in and running ifconfig I receive no result.
Can anyone help ?
EDIT: It appears the install process does not configure the network intereface. I di it manually using nmcli and things now seem to be working.
