I am hoping this is a simple question. Do I load new data to the mounted pool or share? E.g. for a single volume pool I have created, both the pool and share in that pool are mounted (seen via the df command below). dev/sda is the disk in question.
/dev/sdb 7814026584 5839373988 1973951564 75% /mnt2/Classical1share
/dev/sda 7814026584 4539914668 3272645492 59% /mnt2/ClassicalBackup1
/dev/sda 7814026584 4539914668 3272645492 59% /mnt2/ClassicalBackup1Share
/dev/sdb is a RAID1 pool, only the share is mounted.
I ask because when I export the Backup share to Windows, no files are present. Via the command line I can see the files are loaded at the pool level, even though the df command above appears to show the share has the same data as the pool.
