I am trying to install and configure syncthing. I have uninstalled the rockon as I wanted to make some changes to the base configuration. When Iâve rebooted Rockstor and tried to logon I get an error - shown below
I had previously uninstalled and reinstalled the syncthing rockon with no problem. One difference this time is that I had added storage to the syncthing config - not sure of that is relevant or not. I normally reboot the machine after uninstalling but when I tried to log back on I got an error!
Glad your up and running again however that message is a worry. Did you happen to use the ârootâ share for your extra storage. On earlier versions of Rockstor we still surfaced a ârootâ share in our Web-UI. This turned out to be pretty buggy and was not what was intended. More recent versions of Rockstor now no longer expose this âshareâ as if it is used by some rock-ons they can end up break the install by changing write access where they shouldnât. So best avoid using that now legacy share and create dedicated ones for each purpose.
Hi Phill - many thanks for your reply which is much appreciated. When I added a share as additional storage to syncthing, I used a share that I had created myself, though I had used root as the owner of that share.
I have already found a problem with using that share (which is what I was trying to solve). It came up with the error
Failed to create folder root directory mkdir /run/s6/services/syncthing/data: permission denied
This was displayed in the syncthing WebUI.
Should I be avoiding using root as the owner of shares that I create?
OK, so it wasnât the ârootâ share problem I thought it might be then. Thatâs good.
Itâs best if you can; if the Rock-on concerned has a UID/GID setting, to use either of those as the owner/group of the share. We have a disconnect currently in the Web-UI where Rock-ons ask for UID/GID but elsewhere we have user/group names. We will have to address that in time. Again itâs down to the access the Rock-on require of the share. Generally UID input as setting to the Rock-on as owner of the dedicated share should give the Rock-on, by default, full access. As by default the owner of a share has full read and write access. With GID Group ID, it can be a little more tricky depending on the Rock-ons requirements.
