Samba starts to quickly
Samba seems to start before some of the pools have completed mounting properly, this can cause an interesting situation if you start a Write to quickly after rebooting the Rockstor instance where you think you’re writing to one pool but you actually end up dumping it in the root pool
It’s also a pain to then regain access to those files as you have to unmount the pool that’s mounted in that directory to be able to see the files again.
Thanks @Dragon2611 this is a great catch. I’d like to fix this asap, so created a “critical” issue.
I think this is related to this issue, which I ran into.
