Why are sftp and Active Directory enabled now?
Under Services I have sftp and AD enabled. SFTP I can disable, AD I cannot: “Missing configuration. Please configure the service and try again. Exception: expected string or buffer”
3.8-9.01
If I disable SFTP and reboot, it’s back enabled again!
@roweryan Thanks for reporting this, I am now looking into this and believe I have found the problem with sftp but am about to look into the fix for the AD issue which I believe to be related. Will report back here shortly.
@roweryan As you may have already gathered there are now fixes released in the testing branch version 3.8-9.07 that address this “falsely showing enabled” issue on AD and sftp. So the hope is that at least in this regard things should be working more as expected.
Thanks for bringing attention to this issue.
