MinIO - Not able to start the application
Yeah your right, :frowning:
Come back from the first error:
[02/Oct/2024 18:25:10] INFO [storageadmin.views.rockon:505] Rock-on definitions retrieved in: 7.66 seconds.
[02/Oct/2024 18:25:54] INFO [storageadmin.tasks:56] Now executing Huey task [install], id: 050a38c5-d68f-4b54-be7b-dbd5119be1a8.
[02/Oct/2024 18:25:54] ERROR [system.osi:287] non-zero code(1) returned by command: ['/usr/bin/docker', 'stop', 'MinIOcpuV1']. output: [''] error: ['Error response from daemon: No such container: MinIOcpuV1', '']
[02/Oct/2024 18:25:54] ERROR [system.osi:287] non-zero code(1) returned by command: ['/usr/bin/docker', 'rm', 'MinIOcpuV1']. output: [''] error: ['Error response from daemon: No such container: MinIOcpuV1', '']
[02/Oct/2024 18:25:55] INFO [storageadmin.views.rockon:107] Rockon (MinIOcpuV1) state pending and no pending task: assuming task is mid execution.
[02/Oct/2024 18:25:59] INFO [storageadmin.views.rockon:107] Rockon (MinIOcpuV1) state pending and no pending task: assuming task is mid execution.
[02/Oct/2024 18:26:04] INFO [storageadmin.tasks:64] Task [install], id: 050a38c5-d68f-4b54-be7b-dbd5119be1a8 completed OK
Oct 02 18:33:02 DO-DRU-NAS quay.io/minio/minio:RELEASE.2024-09-22T00-33-43Z-cpuv1/MinIOcpuV1[6742]: ERRO: Calculating checksum failed: open minio: no such file or directory
Oct 02 18:33:02 DO-DRU-NAS quay.io/minio/minio:RELEASE.2024-09-22T00-33-43Z-cpuv1/MinIOcpuV1[6742]: FATAL Unable to start listening on console port: address 9001: missing port in address
Have try another time with only :9001, it works :smiley:
Oct 02 18:37:07 DO-DRU-NAS quay.io/minio/minio:RELEASE.2024-09-22T00-33-43Z-cpuv1/MinIOcpuV1[6742]:
Oct 02 18:37:07 DO-DRU-NAS quay.io/minio/minio:RELEASE.2024-09-22T00-33-43Z-cpuv1/MinIOcpuV1[6742]: API: http://172.17.0.2:9000  http://127.0.0.1:9000
Oct 02 18:37:07 DO-DRU-NAS quay.io/minio/minio:RELEASE.2024-09-22T00-33-43Z-cpuv1/MinIOcpuV1[6742]: WebUI: http://172.17.0.2:9001 http://127.0.0.1:9001
Oct 02 18:37:07 DO-DRU-NAS quay.io/minio/minio:RELEASE.2024-09-22T00-33-43Z-cpuv1/MinIOcpuV1[6742]: Docs: https://docs.min.io
Oct 02 18:37:07 DO-DRU-NAS quay.io/minio/minio:RELEASE.2024-09-22T00-33-43Z-cpuv1/MinIOcpuV1[6742]: INFO:
Oct 02 18:37:07 DO-DRU-NAS quay.io/minio/minio:RELEASE.2024-09-22T00-33-43Z-cpuv1/MinIOcpuV1[6742]:  You are running an older version of MinIO released 1 week before the latest release
Oct 02 18:37:07 DO-DRU-NAS quay.io/minio/minio:RELEASE.2024-09-22T00-33-43Z-cpuv1/MinIOcpuV1[6742]:  Update: Run `mc admin update ALIAS`
Thanks a lot Hooverdan for all of your time
The MINIO_CONSOLE_ADDRESS value is your problem — it needs the colon prefix, so `:9001` not just `9001`. Without that colon, Go’s net package reads it as a hostname with no port attached, which is literally what “missing port in address” means. Change that one env var value and the FATAL should disappear. I wrote up both errors (including what that checksum message is actually about) in more detail here: MinIO cpuv1 Rock-on Won’t Start: Fix the Console Address Error - Port & Patch
