OK, this seems not to be hardware related.
The backplane is also not the problem. I had connected the harddrives directly to the mainboard and now it also happened.
Here are two “Screenshots”.
The fist shows where the system hangs.
Now this happens on 4 different systems. So this seems to be a software issue.
I can not find a single real hardware, where Rockstor boots reliably.
Only in VMs there does not seem to be a problem.
Many users maybe do not notice this problem, because storage servers are not rebooted this often.
EDIT: One more info:
I have today also tried without any data harddrive connected. Only the system drive was connected. It hangs on boot also in this case.
This is on KVM? did you try acpi=off and it also looks like ecc isn’t on (not sure that’s an issue for rockstor but it is for other NAS distros).
It looks like there is a sound card error, could you remove the sound card or disable in BIOS and see if that improves? (do you need that sound card?) If it’s a VM you should be able to disable it on the VM.
What hypervisor are you using? What are the VM settings for Storage Driver, memory and BIOS?
I have this same issue just today on the latest update of rockstor, 1x 64GB SSD as boot drive. 10x 500MB configured as 1 for storage. Its just a test / play unit at work so not really any use for it right now.
I will leave it for the day and see if it “heals” itself as Suman said up there somewhere, its btfrs fixing the drives?
If not i will scrap it tomorrow and reinstall the OS
Did you try booting with network cable disconnected? Did it hang anyway?
Completely disabling nfs is maybe not the ideal solution.
Did modifying nfs-config.service not work in your case?
This was my suggestion in the other thread.
I tried booting without network cable, but it got stuck too.
But you are right instead of dialing nfs completely, I could remoint /root
and modify nfs-config.service to start after network is up. Which I did later.
