Samba is 4.2.10 too and the network is static
[root@gphomeserver2 ~]# tail -n 100 /var/log/samba/log.smbd
[2016/10/21 19:46:47.214369, 0] ../lib/util/become_daemon.c:124(daemon_ready)
STATUS=daemon 'smbd' finished starting up and ready to serve connections
[2016/10/21 19:46:47.227972, 0] ../source3/printing/print_cups.c:151(cups_connect)
Unable to connect to CUPS server localhost:631 - Der Socket ist nicht verbunden
[2016/10/21 19:46:47.229002, 0] ../source3/printing/print_cups.c:529(cups_async_callback)
failed to retrieve printer list: NT_STATUS_UNSUCCESSFUL
[2016/10/21 19:53:47.600824, 0] ../source3/printing/print_cups.c:151(cups_connect)
[2016/10/21 19:53:47.601036, 0] ../source3/printing/print_cups.c:529(cups_async_callback)
[2016/10/21 20:06:48.259571, 0] ../source3/printing/print_cups.c:151(cups_connect)
[2016/10/21 20:06:48.260063, 0] ../source3/printing/print_cups.c:529(cups_async_callback)
[2016/10/21 20:09:15.503022, 0] ../lib/util/pidfile.c:153(pidfile_unlink)
Failed to delete pidfile /run/smbd.pid. Error was Datei oder Verzeichnis nicht gefunden
[2016/10/21 20:09:40, 0] ../source3/smbd/server.c:1241(main)
smbd version 4.2.10 started.
Copyright Andrew Tridgell and the Samba Team 1992-2014
[2016/10/21 20:09:40.735791, 0] ../lib/util/become_daemon.c:124(daemon_ready)
[2016/10/21 20:09:40.740626, 0] ../source3/printing/print_cups.c:151(cups_connect)
[2016/10/21 20:09:40.740704, 0] ../source3/printing/print_cups.c:529(cups_async_callback)
[2016/10/21 20:10:40.774434, 0] ../source3/printing/print_cups.c:151(cups_connect)
[2016/10/21 20:10:40.776027, 0] ../source3/printing/print_cups.c:529(cups_async_callback)
[2016/10/21 20:23:41.428054, 0] ../source3/printing/print_cups.c:151(cups_connect)
[2016/10/21 20:23:41.429088, 0] ../source3/printing/print_cups.c:529(cups_async_callback)
[2016/10/21 20:36:42.061556, 0] ../source3/printing/print_cups.c:151(cups_connect)
[2016/10/21 20:36:42.061959, 0] ../source3/printing/print_cups.c:529(cups_async_callback)
[2016/10/21 20:49:42.630931, 0] ../source3/printing/print_cups.c:151(cups_connect)
[2016/10/21 20:49:42.631121, 0] ../source3/printing/print_cups.c:529(cups_async_callback)
[2016/10/21 20:58:44.505054, 0] ../lib/util/pidfile.c:153(pidfile_unlink)
[2016/10/21 20:59:58, 0] ../source3/smbd/server.c:1241(main)
[2016/10/21 20:59:58.372625, 0] ../lib/util/become_daemon.c:124(daemon_ready)
[2016/10/21 20:59:58.399960, 0] ../source3/printing/print_cups.c:151(cups_connect)
[2016/10/21 20:59:58.400163, 0] ../source3/printing/print_cups.c:529(cups_async_callback)
[2016/10/21 21:08:35.479190, 0] ../lib/util/pidfile.c:153(pidfile_unlink)
[2016/10/21 21:09:49, 0] ../source3/smbd/server.c:1241(main)
[2016/10/21 21:09:49.371019, 0] ../lib/util/become_daemon.c:124(daemon_ready)
[2016/10/21 21:09:49.376054, 0] ../source3/printing/print_cups.c:151(cups_connect)
[2016/10/21 21:09:49.376726, 0] ../source3/printing/print_cups.c:529(cups_async_callback)
[2016/10/21 21:11:07.439587, 0] ../lib/util/pidfile.c:153(pidfile_unlink)
[2016/10/21 21:11:07, 0] ../source3/smbd/server.c:1241(main)
[2016/10/21 21:11:07, 0] ../source3/smbd/server.c:1256(main)
error opening config file '/etc/samba/smb.conf'
[2016/10/21 21:15:51, 0] ../source3/smbd/server.c:1241(main)
[2016/10/21 21:15:51, 0] ../source3/smbd/server.c:1256(main)
[2016/10/22 10:16:14, 0] ../source3/smbd/server.c:1241(main)
[2016/10/22 10:16:14, 0] ../source3/smbd/server.c:1256(main)
[2016/10/22 12:28:27, 0] ../source3/smbd/server.c:1241(main)
[2016/10/22 12:28:27, 0] ../source3/smbd/server.c:1256(main)
[2016/10/22 12:55:18, 0] ../source3/smbd/server.c:1241(main)
[2016/10/22 12:55:18, 0] ../source3/smbd/server.c:1256(main)
[2016/10/22 12:57:28, 0] ../source3/smbd/server.c:1241(main)
[2016/10/22 12:57:28, 0] ../source3/smbd/server.c:1256(main)
[2016/10/22 13:12:23, 0] ../source3/smbd/server.c:1241(main)
[2016/10/22 13:12:23, 0] ../source3/smbd/server.c:1256(main)
Adding local master = no did not work
File "/opt/rockstor/src/rockstor/smart_manager/views/samba_service.py", line 84, in post
restart_samba(hard=True)
File "/opt/rockstor/src/rockstor/system/samba.py", line 228, in restart_samba
run_command([SYSTEMCTL, mode, 'smb'])
File "/opt/rockstor/src/rockstor/system/osi.py", line 109, in run_command
CommandException: Error running a command. cmd = ['/usr/bin/systemctl', 'restart', 'smb']. rc = 1. stdout = ['']. stderr = ['Job for smb.service failed because the control process exited with error code. See "systemctl status smb.service" and "journalctl -xe" for details.', '']
