I wanted to provide an update on this. I got an ssd, made an install drive from the latest iso, installed sucessfully. When I reboot the machine the system starts no problem, however the web ui is not available. I first see that initrock is empty so I follow another forum post to run /opt/rockstor/bin/initrock I then get this. There appears to be something wrong.
2017-04-07 23:30:58,240: Supported kernel(/boot/vmlinuz-4.8.7-1.el7.elrepo.x86_64) is already the default
2017-04-07 23:30:58,330: /etc/rc.d/rc.local looks correct. Not updating.
2017-04-07 23:30:58,331: Checking for flash and Running flash optimizations if appropriate.
2017-04-07 23:30:59,241: Updating the timezone from the system
2017-04-07 23:30:59,242: system timezone = America/New_York
2017-04-07 23:30:59,244: Updating sshd_config
2017-04-07 23:30:59,247: sshd_config already has the updates. Leaving it unchanged.
2017-04-07 23:30:59,247: Please be patient. This script could take a few minutes
2017-04-07 23:30:59,391: initializing Postgresql...
2017-04-07 23:31:01,255: Done.
2017-04-07 23:31:02,500: Creating app databases...
2017-04-07 23:31:04,465: Done
2017-04-07 23:31:04,465: Initializing app databases...
File "/opt/rockstor/bin/initrock", line 45, in <module>
sys.exit(scripts.initrock.main())
File "/opt/rockstor/src/rockstor/scripts/initrock.py", line 383, in main
run_command(['su', '-', 'postgres', '-c', "psql storageadmin -f %s/conf/storageadmin.sql.in" % BASE_DIR]) # noqa E501
File "/opt/rockstor/src/rockstor/system/osi.py", line 110, in run_command
system.exceptions.CommandException: Error running a command. cmd = su - postgres -c psql storageadmin -f /opt/rockstor//conf/storageadmin.sql.in. rc = 2. stdout = ['SET', 'SET', 'SET', 'SET', 'SET', 'CREATE EXTENSION', 'COMMENT', 'SET', 'SET', 'SET', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', 'CREATE TABLE', 'ALTER TABLE', 'CREATE SEQUENCE', 'ALTER TABLE', 'ALTER SEQUENCE', '']. stderr = ['psql:/opt/rockstor/conf/storageadmin.sql.in:1134: WARNING: terminating connection because of crash of another server process', 'DETAIL: The postmaster has commanded this server process to roll back the current transaction and exit, because another server process exited abnormally and possibly corrupted shared memory.', 'HINT: In a moment you should be able to reconnect to the database and repeat your command.', 'psql:/opt/rockstor/conf/storageadmin.sql.in:1134: server closed the connection unexpectedly', '\tThis probably means the server terminated abnormally', '\tbefore or while processing the request.', 'psql:/opt/rockstor/conf/storageadmin.sql.in:1134: connection to server was lost', '']
