Upgrade to 5.0.1-0 from 4.6.1 rockstor fails
Glad we could work it all out!
Thank you for not only reporting this, but also your help in figuring it all out!
One point: do you remember if you ever manually install postgresql14 on that machine (before or after the move to 15.4)? We’re just trying to see if there is a reproducible scenario that would lead to the situation in which you found yourself.
Hi @Flox,
I do not know how postgresql14 was installed as I learnt from your troubleshooting how to install postgresql13 :slight_smile:
I had to uninstall with Rock-ons and install them again as they were broken for some reason. They are all now working just fine.
thanks
