Serial Number: WD-WX32DB0R7SEP
Serial Number: 78EWNTNAS
first drive output was:
ID_SCSI=1
ID_VENDOR=External
ID_VENDOR_ENC=External
ID_MODEL=USB3.0_DISK03
ID_MODEL_ENC=USB3.0\x20DISK03\x20\x20\x20
ID_REVISION=0103
ID_TYPE=disk
ID_SERIAL=33044564198838960
ID_SERIAL_SHORT=3044564198838960
ID_SERIAL_COMPAT=
ID_WWN=0x3044564198838960
ID_WWN_WITH_EXTENSION=0x3044564198838960
ID_SCSI_SERIAL=DD5641988389F
second
ID_SCSI=1
ID_VENDOR=External
ID_MODEL=USB3.0_DISK04
ID_MODEL_ENC=USB3.0\x20DISK04\x20\x20\x20
ID_REVISION=0103
ID_TYPE=disk
ID_SERIAL_COMPAT=
Mhm, it seems then that in your case, not even the serial numbers (SCSI or otherwise) are differentiated. In @greg_r’s case serial numbers were different (matching the ones on the printed label) which then allowed for that script/udev rule combination to work. In your case, since there is no “good” differentiating factor (and the ID_MODEL based on which bay the disk is in, is likely not a good candidate) I don’t think the approach outlined by @greg_r will work for you.
Which orico enclosure model are you using?
I have 6558US3-C, it also say 5HDD duplicator, that might be the issue?
Good question. another shot in the dark from my side, if you run
sudo smartctl --all /dev/sda and sudo smartctl -all /dev/sdb
what do you get then? It might be that smartctl actually provides the “real” serial number instead of the one the enclosure overrides.
not sure if I am doing it correctly:
darkdeny@Shanghai:~> sudo smartctl -all /dev/sdb
smartctl 7.2 2021-09-14 r5237 [x86_64-linux-5.14.21-150400.24.46-default] (SUSE RPM)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=======> INVALID ARGUMENT TO -l: l
=======> VALID ARGUMENTS ARE: error, selftest, selective, directory[,g|s], xerror[,N][,error], xselftest[,N][,selftest], background, sasphy[,reset], sataphy[,reset], scttemp[sts,hist], scttempi
nt,N[,p], scterc[,N,M], devstat[,N], defects[,N], ssd, gplog,N[,RANGE], smartlog,N[,RANGE], nvmelog,N,SIZE <=======
I think I got it
first hdd:
darkdeny@Shanghai:~> sudo smartctl /dev/sdb --all
Model Family: Toshiba P300 (CMR)
Device Model: TOSHIBA HDWD130
LU WWN Device Id: 5 000039 fe6e8c317
Firmware Version: MX6OACF0
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Thu Apr 11 19:08:31 2024 MSK
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
second:
darkdeny@Shanghai:~> sudo smartctl /dev/sda --all
Model Family: Western Digital Blue (SMR)
Device Model: WDC WD40EZAZ-00SF3B0
Firmware Version: 0967
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Sector Size: 512 bytes logical/physical
ATA Version is: ATA/ATAPI-7 (minor revision not indicated)
Local Time is: Thu Apr 11 19:09:29 2024 MSK
That’s a good sign. So, I think, you could place the line in the bash script that contain hdparm with this line:
replace this:
SERIAL=`expr substr "$(/sbin/hdparm -I $1 | grep Serial\ Number)" 22 8`
with this:
SERIAL=`expr substr "$(/usr/sbin/smartctl --all $1 | grep Serial\ Number)" 19 20`
Save, exit.
File is already set to executable since you ran it already (otherwise chmod +x orico_id)
try running the orico_id /dev/sda and orico_id /dev/sdb … theoretically the Serials should now be different, and then you should be able to use the dev rule as it was written above.
hmm, not sure I am getting correct result
darkdeny@Shanghai:~> /usr/lib/udev/orico_id /dev/sdc
ID_SCSI=1
ID_VENDOR=
ID_VENDOR_ENC=
ID_MODEL=
ID_MODEL_ENC=
ID_REVISION=
ID_TYPE=
darkdeny@Shanghai:~> /usr/lib/udev/orico_id /dev/sda
ID_SCSI=1
ID_VENDOR=
ID_VENDOR_ENC=
ID_MODEL=
ID_MODEL_ENC=
ID_REVISION=
ID_TYPE=
darkdeny@Shanghai:~> /usr/lib/udev/orico_id /dev/sdb
ID_SCSI=1
ID_VENDOR=
ID_VENDOR_ENC=
ID_MODEL=
ID_MODEL_ENC=
ID_REVISION=
ID_TYPE=
what could I miss to change?
Mhm, it looks like it’s just printing what smartctl provides (empty, too).
This is the code I changed and ran:
#!/bin/sh
SERIAL=`expr substr "$(/usr/sbin/smartctl --all $1 | grep Serial\ Number)" 22 8`
SERIAL_HEX=`echo -n "$SERIAL" | xxd -ps -c 200`
EXPORTS=`/usr/lib/udev/scsi_id --export --whitelisted -d $1`
EXPORTS="${EXPORTS/ID_SERIAL=33000000000000000/ID_SERIAL=ORICO_hdparm-sn-$SERIAL}"
EXPORTS="${EXPORTS/ID_SERIAL_SHORT=3000000000000000/ID_SERIAL_SHORT=$SERIAL}"
EXPORTS="${EXPORTS/ID_WWN=0x3000000000000000/ID_WWN=0x$SERIAL_HEX}"
EXPORTS="${EXPORTS/ID_WWN_WITH_EXTENSION=0x3000000000000000/ID_WWN_WITH_EXTENSION=0$SERIAL_HEX}"
echo "$EXPORTS"
which then results in an output like this (granted I don’t have the enclosure but virtual disks, but the original smartctl command we both tried provided the same relevant output.
rockwurst:~ # /usr/lib/udev/orico_id /dev/sda
ID_SCSI=1
ID_VENDOR=ATA
ID_VENDOR_ENC=ATA\x20\x20\x20\x20\x20
ID_MODEL=VBOX_HARDDISK
ID_MODEL_ENC=VBOX\x20HARDDISK\x20\x20\x20
ID_REVISION=1.0
ID_TYPE=disk
ID_SERIAL=1ATA_VBOX_HARDDISK_VB409035cf-baf0db55
ID_SERIAL_SHORT=ATA_VBOX_HARDDISK_VB409035cf-baf0db55
ID_SERIAL_COMPAT=
ID_SCSI_SERIAL=VB409035cf-baf0db55
smartctl 7.2 2021-09-14 r5237 [x86_64-linux-5.14.21-150400.24.100-default] (SUSE RPM)
Device Model: VBOX HARDDISK
Serial Number: VB409035cf-baf0db55
so, not sure. since I’m using PuTTY and am logged in as root that’s the only difference I would see.
Well, this shows you, that I don’t really know bash all that well. Looking more into the program above, it seems in the end it only prints the output of the line
Since in my VM based example all items are populated correctly, it shows up just fine.
If I understand correctly the other export lines below are bash-based replacements. So, in your case using the above information those lines probably need to look like this:
EXPORTS="${EXPORTS/ID_SERIAL=33044564198838960/ID_SERIAL=ORICO_hdparm-sn-$SERIAL}"
EXPORTS="${EXPORTS/ID_SERIAL_SHORT=33044564198838960/ID_SERIAL_SHORT=$SERIAL}"
EXPORTS="${EXPORTS/ID_WWN=0x3044564198838960/ID_WWN=0x$SERIAL_HEX}"
EXPORTS="${EXPORTS/ID_WWN_WITH_EXTENSION=0x3044564198838960/ID_WWN_WITH_EXTENSION=0$SERIAL_HEX}"
within the original export it searches for the combo of the variable, e.g. ID_SERIAL along with its assigned value, which should be your “fake” serial number, and then replaces it with the one gleaned from the first command, following this syntax
${variable//pattern/replacement}
still don’t know, why suddenly nothing shows up for you at all … you might have to fiddle with the replacements to populate all relevant fields correctly … again, limited knowledge from my side on both bash and udev rules.
As an aside, here is a nice tutorial on the various ways on how to deal with variables (substitution is in section 5):
https://www.cyberciti.biz/tips/bash-shell-parameter-substitution-2.html
I finally broke through some my mistakes, now script reports different ids for different hdds:
darkdeny@Shanghai:~> sudo /usr/lib/udev/orico_id /dev/sda
hdd serial is WX32DB0R
hex serial is 5758333244423052
ID_SCSI=1
ID_VENDOR=External
ID_REVISION=0103
ID_TYPE=disk
ID_SERIAL=ORICO_hdparm-sn-WX32DB0R
ID_SERIAL_SHORT=WX32DB0R
ID_SERIAL_COMPAT=
ID_WWN=0x5758333244423052
ID_WWN_WITH_EXTENSION=05758333244423052
darkdeny@Shanghai:~> sudo /usr/lib/udev/orico_id /dev/sdb
hdd serial is WNTNAS
hex serial is 574e544e4153
ID_SCSI=1
ID_VENDOR=External
ID_REVISION=0103
ID_TYPE=disk
ID_SERIAL=ORICO_hdparm-sn-WNTNAS
ID_SERIAL_SHORT=WNTNAS
ID_SERIAL_COMPAT=
ID_WWN=0x574e544e4153
ID_WWN_WITH_EXTENSION=0574e544e4153
but in the WebUI it still reports duplicated serial.
Finally I also was able to replace ID_SCSI_SERIAL in my script, but that is not enough yet. I wonder what other variables I need to replace?..
I updated /usr/lib/udev/rules.d/60-persistent-storage.rules with my serial, but no luck yet.
Is there a way to debug/diagnose those udev rules from /usr/lib/udev/rules.d/ folder?
from what I understand you can increase the log level by
udevadm control --log-level=debug
and then you can check with in journalctl (maybe with journalctl -f if you’re executing a udev rule in the running system, otherwise not that option)
Once, done, set it back to the original setting:
udevadm control --log-level=info
