Using a DL360G5 with a LSI Logic / Symbios Logic SAS1068E PCI-Express Fusion-MPT SAS HBA ans a MSA70 Diskshelf filled with 25 146GB SAS Disk. Runs perfect, except that there are no smart values for that disks. On console, everything looks fine.
[root@rock log]# smartctl --scan
/dev/sda -d scsi # /dev/sda, SCSI device
/dev/sdb -d scsi # /dev/sdb, SCSI device
/dev/sdc -d scsi # /dev/sdc, SCSI device
[root@rock log]# smartctl --all /dev/sdc
smartctl 6.2 2013-07-26 r3841 [x86_64-linux-4.2.2-1.el7.elrepo.x86_64] (local build)
Copyright © 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Vendor: HP
Product: DG146A4960
Revision: HPDB
User Capacity: 146.815.737.856 bytes [146 GB]
Logical block size: 512 bytes
Rotation Rate: 10020 rpm
Logical Unit id: 0x5000cca000131464
Serial number: P4VAH8XA
Device type: disk
Transport protocol: SAS
Local Time is: Tue Nov 3 09:08:12 2015 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
Temperature Warning: Enabled
SMART Health Status: OK
Current Drive Temperature: 43 C
Drive Trip Temperature: 70 C
Manufactured in week 43 of year 2007
Specified cycle count over device lifetime: 50000
Accumulated start-stop cycles: 19
Elements in grown defect list: 0
Vendor (Seagate) cache information
Blocks sent to initiator = 5583279327543296
Error counter log:
Errors Corrected by Total Correction Gigabytes Total
ECC rereads/ errors algorithm processed uncorrected
fast | delayed rewrites corrected invocations [10^9 bytes] errors
read: 0 0 0 0 0 0,000 0
write: 0 0 0 0 0 0,000 0
Non-medium error count: 130
No self-tests have been logged
BTW: Rockstore maxout the 12Gbit SAS Connection to the MSA70 when in jbod/raid0 mode. Well done. Never reached this poing with zfs
