Hello all, Happy to be here, thanks for looking and I hope this find you and yours well. Rockstor has worked well enough for me so far, despite my lack of knowledge regarding the software. I have come to my first failure.
I was able to get it mounted once with the adding degraded,ro to the extra mount options but now has not worked the last couple times I booted it trying to get more info for this post. I will need help figuring out how to locate the error-ing disk for replacement but first I need a replacement. So that leads me to my explanation of why I am leaning toward option #1.
#1 I need more space, they have a 2.5million hr mttf, at $144 one a year or so is not crazy and did I mention the space? I would do the whole make it act like it’s just a 8TB drive like the rest but in 4 months all 8 would be option #1.
#2 is a way to go, designed for nas, solid mttf, not used, I have space in my case for 4 more drives and my SAS card has 4 more connections so I can get more space. #2 cost slows the upgrade and over all the space increase is minimal with only 4 more addable.
Outside of all that, I need to know how will the system handle? usage is a $#!T ton of pron! JK
It’s my whole movie collection, lots for 4K and lots more Blu-ray.
P.S. I chose Raid6 because I want a lil’parity but Space! If it crashes and burns it just means a few months of ripping, again, Freenas… Anyway thanks again for looking and now the current stats and upgrade options with links. Cheers!
Current Mobo: GIGABYTE GA-78LMT-USB3 R2 AMD 760G USB 3.1 HDMI Micro ATX Motherboard
Current CPU: AMD CPU FX Series FX-4100 Quad Core CPU 3.6GHz Socket AM3+
Current Memory: Team Group TED38G1600C11BK 32GB 8GB x 4 DDR3 1600mhz Kit
Power Supply: Unable to locate purchase online. EVGA 500W
System drive: Kingston data Travler DT50 16GB
Storage drives: Seagate Barracuda Compute Model# ST8000DM004 8TB 5400rpm x 8
Case: GIGABYTE 3D AURORA GZ-FSCA1-ANB Black Aluminum ATX Full Tower
Rockstor Setup: Linux: 6.5.1-lp154.2.gc181e32-default Opted for Raid 6 I have not chosen an update path but I have started a stable updates sub to support the cause.
In order of current prefrence.
Upgrade consideration # 1: WD Ultrastar DC HC530 14TB 7200RPM SATA 6Gb/s 3.5-inch Enterprise HDD - WUH721414ALE6L4 (Renewed)
Upgrade Consideration # 2: Seagate IronWolf 8TB NAS Internal Hard Drive HDD – 3.5 Inch SATA 6Gb/s 7200 RPM 256MB Cache (ST8000VNZ04/N004)
