hi.
I have faced with strange activity. 100% cpu load on one core. Plex rock on not responding. Docker stop has no effect.
what is it?
hi.
what is it?
I’ve seen BTRFS or btrfs-transaction sit there at 100% for a while before, it’s usually when doing something like deleting a lot of data, running a balance or deleting snapshots.
Essentially anything that requires BTRFS to perform cleanup or re-write a load of metadata I would guess.
how often and how long it will be running?
System services are inaccessible.
I have snapshot schedule for one share (12Gb) every 5 minutes.
Does that snapshot discard the old ones frequently and how much data changes?
It could well be that but I’m just guessing here.
If btrfs-transacti process is at 100%, type:
btrfs quota rescan -s <PATH_TO_POOL>
If a quota rescan is running and it’s always on the same key, this is the culprit. You need to disable quotas.
btrfs quota disable <PATH_TO_POOL>
You may need to reboot before this command will work.
If this fixes, you’ll then have another problem: the service rockstor-bootstrap.service won’t start without quotas enabled, which means dependent services like smb won’t start:
btrfs quota enable <PATH_TO_POOL>
Start services:
systemctl start rockstor-bootstrap.service
systemctl start smb
systemctl start <ANY_OTHER_SERVICES_YOU'RE_MISSING>
Disable quotas again:
Can automate this in a startup shell script.
[root@server ~]# btrfs quota rescan -s /mnt2/documents/
rescan operation running (current key 1031017570305)
rescan operation running (current key 1032447197185)
rescan operation running (current key 1033334620161)
rescan operation running (current key 1033772036097)
rescan operation running (current key 1034042638337)
Key is different. Every 5 minutes (according to snapshot schedule) CPU utilization is 100%, this issue affects other services.
SMB share is not responsive.
I’d just disable quotas anyway (unless you need them). Btrfs quotas are still performance hogs: “When the quotas are turned on, they affect all extent processing, taking a performance hit. It is not recommended to turn on qgroups unless the user intends to actually use them”
I’ve disabled quotas. Problem has gone.
Thanks!
