6 drive RAID 10 triple redundant instead of double
I’ve tried researching on my own, maybe I don’t know how to phrase it.
I’m wanting to build a RAID 10 with six 3Tb drives.
I’m looking to set up up a bit differently than what I can find on the net.
Instead of 2 redundant arrays of replication I’m going for 3.
                         RAID 0
          RAID 1                 RAID 1
        A1 B1 C1              A2 B2 C2
        A1 B1 C1              A2 B2 C2
        A1 B1 C1              A2 B2 C2
does this make sense?
Is this possible?
I’m sorry if this is in the wrong category.
Thanks,
@Ben First off - welcome to the Rockstor community forum.
As btrfs’s raid works at the chunk level and it’s current implementation of raid1 is 2 way not n-way, you can’t define what you are after, assuming you are specifying a 3-way raid 1 (at the lower level): ie 3 copies of everything. Btrfs raid 1 only does 2 copies on 2 different devices and btrfs raid 10 is, as you indicate, a stripe over 2 or more raid1(2-way) mirrored drives(at the chunk level). So note that if you have 3 drives in btrfs raid1, one chunk may be on drive 1 and 2 while another chunk may be on drive 2 and 3 so chunk not drive level of raid.
@Spectre694 does a nice explanation of btrfs raid levels and capabilities in the following thread started by @Bayonet:
Helps a lot, Thanks!
@Ben
Cheers, let us know how you get on.
Is it possible to Raid-1 mirror on 3 drives (triple copy rather than double) of the same size using BTRFS?
or no matter what, RAID 1 is two copies only?
I love BTRFS for the bitrot protection, and am really looking for a triple copy of my information (really don’t want to risk losing anything)
Afraid not regardless of what you do BTRFS RAID 1 is a 2 way setup and it isn’t possible to do n-way. The only way to be able to survive a two disk failure with BTRFS is by using RAID 6. HOWEVER BTRFS’s RAID 5/6 has been found to have multiple severe bugs and cannot be recommended at the moment.
