Hi. I have a Rock-On stuck. I know it’s stuck, as I can’t do anything else… Reboots don’t solve it, and it’s not running under docker. When I try and do something else with Rock-Ons, it displays the above message. Any way I can get it out from a pending state?
Ah. A bit of searching, and found /opt/rockstor/bin/delete-rockon
No I get - Rockon(Sonarr) is in pending state but there is no pending or failed task for it.
Nice find of this script, it definitively is a very handy one. I was about to suggest this script to you as it should clear everything up.
would you be able to confirm the command and its output? Based on the information, it should be:
/opt/rockstor/bin/delete-rockon Sonarr
