Any way to manually run a replication 'send' task
I am seeding initial replication tasks between 2 Rockstar appliances. Is there any way to manually run the replication tasks after they have been scheduled?
As a workaround, via the WebUI you could temporarily change the replication frequency to, say, every 5 minutes and then change it back later to whatever frequency you’ve had before. Just click on the replication task name, change the frequency in the subsequent screen and select Submit.
