Hello. I don’t know why my NAS started going to 80 Mb/s but after some time started to go to 4 Mb/s and now is going to 1,07 Mb/s. Is better for me to have a pile with the 4 drives it contains and plug them directly using a bad USB adapter to make them work at this point.
Can someone help me to see where is the bug? What should I check first?
I checked the cables, all are OK and with 8 wires each one. I have 3 switches between them in the same room (I have some printers and things that require that amount of switches) but never had a problem with them, I have the problem when plugged only with one switch in middle too, and short cables.
I’m using Windows 7 now, but the problem happens with Debian 9.6 too.
Thanks for any help. Regards.
