can anyone explain how to connect to it remotely.thanks
It appears to default to port 4040, so I would try http;//<ip/hostname of nas>:4040/
Beyond that, the Rockstor UI should have a button that redirects to the booksonic UI in the rock-ons list once it’s installed.
the ip part is that my out side ip or my internal ip
That is your local network IP of your Rockstor system, and will only be accessible from inside your network.
If you wish to use it from outside your network, you’ll need to configure a port forward on your network’s router to send traffic on the port provided to your NAS.
The configuration for this depends largely on your home router.
Ok I have configured my router to forward the recommended port and still I can not get to connect.
