Hi, After failing to install multiple time, i finally got the installer to run by editing the install command on the grub screen to target my USB drive via UUID instead of label.
Now im failing in the install itself right at the end, with an error about writing the bootloader configuration, and a message saying the drive wont be bootable.
This is the log:
03:04:13,431 DEBUG anaconda: Left spoke: PasswordSpoke
03:05:22,362 INFO anaconda: Installing boot loader
03:05:22,362 INFO anaconda: boot loader stage1 target device is nvme0n1p1
03:05:22,362 INFO anaconda: boot loader stage2 target device is nvme0n1p2
03:05:22,363 DEBUG anaconda: new default image: <pyanaconda.bootloader.LinuxBootLoaderImage object at 0x465c6d0>
03:05:22,416 INFO anaconda: bootloader.py: used boot args: crashkernel=auto rd.lvm.lv=rockstor/root rd.lvm.lv=rockstor/swap rhgb quiet
03:05:22,564 ERR anaconda: bootloader.write failed: failed to write boot loader configuration
03:05:30,250 DEBUG anaconda: running handleException
03:05:30,250 CRIT anaconda: Traceback (most recent call last):
File "/usr/lib64/python2.7/site-packages/pyanaconda/threads.py", line 227, in run
threading.Thread.run(self, *args, **kwargs)
File "/usr/lib64/python2.7/threading.py", line 764, in run
self.__target(*self.__args, **self.__kwargs)
File "/usr/lib64/python2.7/site-packages/pyanaconda/install.py", line 254, in doInstall
writeBootLoader(storage, payload, instClass, ksdata)
File "/usr/lib64/python2.7/site-packages/pyanaconda/bootloader.py", line 2440, in writeBootLoader
writeBootLoaderFinal(storage, payload, instClass, ksdata)
File "/usr/lib64/python2.7/site-packages/pyanaconda/bootloader.py", line 2368, in writeBootLoaderFinal
storage.bootloader.write()
File "/usr/lib64/python2.7/site-packages/pyanaconda/bootloader.py", line 1773, in write
self.write_config()
File "/usr/lib64/python2.7/site-packages/pyanaconda/bootloader.py", line 1572, in write_config
raise BootLoaderError("failed to write boot loader configuration")
BootLoaderError: failed to write boot loader configuration
Im trying to install on an Odroid H2 with an NVME ssd
