My Rockstor setup has been giving me ctree errors
btrfs check gives me
BTRfs check errors found in extent allocation tree
would my best options to be perform a btrfs restore to a new disk, if so does that disk need to be BTRFS as well?
or should i try a repair or both? thoughts?
[root@host ~]# btrfs check --readonly /dev/sdd
Opening filesystem to check…
Checking filesystem on /dev/sdd
UUID: cad74c1c-dee1-470a-9b29-c66e3b02a54f
[1/7] checking root items
[2/7] checking extents
leaf parent key incorrect 11905083211776
bad block 11905083211776
ERROR: errors found in extent allocation tree or chunk allocation
[3/7] checking free space cache
[4/7] checking fs roots
[5/7] checking only csums items (without verifying data)
Error looking up extent record -1
csum exists for 6400691458048-6400691466240 but there is no extent record
csum exists for 6400691470336-6400892633088 but there is no extent record
csum exists for 6400892665856-6401102372864 but there is no extent record
csum exists for 6401102381056-6401252388864 but there is no extent record
csum exists for 6401252397056-6401252446208 but there is no extent record
csum exists for 6401252450304-6401336623104 but there is no extent record
csum exists for 6401336659968-6401336668160 but there is no extent record
csum exists for 6401336672256-6401397280768 but there is no extent record
csum exists for 6401397293056-6401461456896 but there is no extent record
csum exists for 6401461477376-6401461510144 but there is no extent record
csum exists for 6401461514240-6401544380416 but there is no extent record
csum exists for 6401544413184-6401659756544 but there is no extent record
csum exists for 6401659764736-6401710186496 but there is no extent record
csum exists for 6401710190592-6401710215168 but there is no extent record
csum exists for 6401710219264-6401794052096 but there is no extent record
csum exists for 6401794056192-6401794109440 but there is no extent record
csum exists for 6401794113536-6401919492096 but there is no extent record
csum exists for 6401919496192-6401919610880 but there is no extent record
csum exists for 6401919614976-6402020196352 but there is no extent record
csum exists for 6402020200448-6402121461760 but there is no extent record
csum exists for 6402121465856-6402194391040 but there is no extent record
csum exists for 6402194395136-6402194468864 but there is no extent record
csum exists for 6402194472960-6402194534400 but there is no extent record
csum exists for 6402194538496-6402229907456 but there is no extent record
csum exists for 6402229911552-6402265591808 but there is no extent record
csum exists for 6402265595904-6402265636864 but there is no extent record
csum exists for 6402265640960-6402409107456 but there is no extent record
csum exists for 6402409111552-6402455277568 but there is no extent record
csum exists for 6402455289856-6402455302144 but there is no extent record
csum exists for 6402455330816-6402455347200 but there is no extent record
csum exists for 6402455351296-6402502856704 but there is no extent record
csum exists for 6402502877184-6402538266624 but there is no extent record
csum exists for 6402538270720-6402574561280 but there is no extent record
csum exists for 6402574569472-6402574630912 but there is no extent record
csum exists for 6402574647296-6402610356224 but there is no extent record
ERROR: errors found in csum tree
[6/7] checking root refs
[7/7] checking quota groups skipped (not enabled on this FS)
found 5267514257408 bytes used, error(s) found
total csum bytes: 0
total tree bytes: 62521344
total fs tree bytes: 0
total extent tree bytes: 61734912
btree space waste bytes: 16604435
file data blocks allocated: 1437335552
referenced 1437335552
[root@host ~]# btrfs fi show
Label: ‘rockstor_rockstor’ uuid: 2e34fb77-7712-4356-9582-1cc853a2b830
Total devices 1 FS bytes used 9.15GiB
devid 1 size 66.59GiB used 38.05GiB path /dev/sdh3
Label: ‘externalwork’ uuid: c29e2829-cde6-4ce5-9920-56edf398b908
Total devices 1 FS bytes used 5.12GiB
devid 1 size 465.76GiB used 13.02GiB path /dev/sdg
Label: ‘Primary’ uuid: cad74c1c-dee1-470a-9b29-c66e3b02a54f
Total devices 6 FS bytes used 5.30TiB
devid 1 size 1.82TiB used 1.08TiB path /dev/sdd
devid 2 size 1.82TiB used 1.08TiB path /dev/sde
devid 3 size 1.82TiB used 1.08TiB path /dev/sdf
devid 4 size 1.82TiB used 1.08TiB path /dev/sda
devid 5 size 1.82TiB used 1.08TiB path /dev/sdc
devid 6 size 1.82TiB used 1.08TiB path /dev/sdb
