Hello,
Just got an HBA card failure where I’ve got some raid deices. HBA has been changed and with a RAID5 I’ve got one of the HDD’s with IO failure. Now in theory the RAID5 should work in degraded state but seems that there is another one affected.
[29095.898222] BTRFS info (device sdp): allowing degraded mounts
[29095.898225] BTRFS info (device sdp): use no compression, level 0
[29095.898226] BTRFS info (device sdp): disk space caching is enabled
[29095.898227] BTRFS info (device sdp): has skinny extents
[29095.899308] BTRFS warning (device sdp): devid 1 uuid abc0612f-26ae-432c-998f-2982859d9734 is missing
[29096.680236] BTRFS critical (device sdp): corrupt leaf: root=7 block=11411345801216 slot=1, unexpected item end, have 16124 expect 16118
[29096.680238] BTRFS error (device sdp): block=11411345801216 read time tree block corruption detected
[29096.680311] BTRFS error (device sdp): failed to verify dev extents against chunks: -5
[29096.808034] BTRFS error (device sdp): open_ctree failed
Tried to recover the sdp device:
# btrfs check /dev/sdp
Opening filesystem to check…
warning, device 1 is missing
checksum verify failed on 24231936 found B3CF6D9D wanted 572CD02B
bad tree block 24231936, bytenr mismatch, want=24231936, have=0
Couldn’t read chunk tree
ERROR: cannot open file system
# btrfs rescue zero-log /dev/sdp
Couldn't read chunk tree
ERROR: could not open ctree
# btrfs check --repair /dev/sdp
enabling repair mode
Opening filesystem to check...
# btrfs rescue super-recover /dev/sdp
All supers are valid, no need to recover
Tried:
# btrfs rescue chunk-recover /dev/sdp
Scanning: 542572544 in dev0, 560910336 in dev1, 543621120 in dev2, 540463104 in dev3
but got segemntation fault after a while.
Any clue from anyone?
