Can not create an SFTP share on openSUSE
When trying to create an SFTP share on openSUSE I got the following error:
[Errno 2] No such file or directory: '/lib64/libpopt.so.0'
  File "/opt/rockstor/src/rockstor/storageadmin/views/sftp.py", line 80, in post
    rsync_for_sftp(chroot_loc)
  File "/opt/rockstor/src/rockstor/system/ssh.py", line 127, in rsync_for_sftp
    ('%s/lib64' % chroot_loc))
  File "/usr/lib64/python2.7/shutil.py", line 133, in copy
    copyfile(src, dst)
  File "/usr/lib64/python2.7/shutil.py", line 96, in copyfile
    with open(src, 'rb') as fsrc:
IOError: [Errno 2] No such file or directory: '/lib64/libpopt.so.0'
zypper says libpopt0 is already installed. I can find it at /usr/lib64/libpopt.so.0, so the code is possibly looking for it in the wrong place?
@freaktechnik Nice find.
Let us know if you make an progress in tracking this down any further.
I’d look to this bit first:
I.e. chroot_loc may be set wrong. Haven’t been there for ages. If you take a look at a few recent [openSUSE] related commits you can see how we do stuff contextually using distro. That may be all we need here. But again, I haven’t looked into this yet but if you fancy doing so then great.
Thanks again for a nice report and do post here any progress. Once we have the root cause you could create a GitHub issue to get this one sorted if you fancy:
Developers subsection of Contributing to Rockstor:
http://rockstor.com/docs/contribute.html#developers
Thanks again for the report and if you do get to creating a GitHub issue for this, once it’s clarified a tad, remember to link back to this forum post.
@freaktechnik, @phillxnet, I was waiting for a computation to run so I had a few minutes to kill.
I thus looked and indeed, we are looking in the wrong place, it seems as we have the libs location hardcoded (for centOS, I assume) here:
As per @freaktechnik findings, it seems like we should use /usr/lib64 instead of /lib64/ in line 126 (assuming all the other libs have the same location as well in openSUSE.
It appears only libpopt is in /usr/lib64 on openSUSE, the other ones are still native system libs.
Reported on GitHub as
@freaktechnik Hello again.
On a quick related developer note, how is @Flox’s fix for your reported:
working out in 3.9.2-58, I’m assuming it’s working for you as tested in pr:
Cheers.
SFTP shares work fine now, thanks.
@freaktechnik Thanks for the confirmation.
I can pop this in the beta release notes. Always good to have additional confirmation, just in case the developer and reviewer missed the same thing/things: @Flox and me respectively in this case.
Thanks for actively helping with Rockstor’s development by the way. I’m quite looking forward to having this whole CentOS to ā€˜Built on openSUSE’ move over and done with and we are very nearly there now.
Cheers.
