I switched the service on. (shell in a box)
To begin with I got “Bad Gateway”. After reading other posts I went to the configuration of the service and clicked “apply” without changing anything.
Now I get a shell but it just says “connection closed”. there is a connect button but clicking it seems to have little effect (a slight flicker maybe).
I try changing the service config to use ssh.
Now I get a user/password prompt in the shell -> but cant log in. I am using the same user/pw that I log into the web interface with.
any help?
