Just stumbled on cloudron.io. Basically it is a GUI to manage Docker images. Instead of developing a rockstor specific solution I’d like to suggest to have a look at it.
Best Regards
Christoph
Best Regards
Christoph
Digging deeper I could not find the source code to their software. Probably no integration possible. It still can serve as an example how rock-on apstore could look and feel like.
Cloudron is now opensource - https://cloudron.io/blog/2016-08-29-opensource.html . Yes, It’s appstore based on Docker as OP mentions.
