bug11
((git user tronder88))
March 13, 2016, 12:06pm
1
Im currently working on a rock-on, and usually always get an error containging the followin message:
Lower level exception: Expecting property name:
anyone care to help sort this out?
Thanks
EDIT: error in code. found the mistake and looks like all is good
bug11
March 13, 2016, 3:09pm
2
New case:
I have created json file, and installed. However repository on hub.docker.com was empty (no docker image).
Now I cannot remove the “installed” docker, nor can I change repository without creating a New JSON file.
Any ideas?
Schrauber
(Maik Opitz)
March 15, 2016, 9:14am
3
What happens if you try to remove?
bug11
March 15, 2016, 10:44am
4
I cannot remove, because rockstor has not installed the image.
so there is nothing to remove.
However, in some weird database is a reference to the installation, which blocks the port availability and changes in JSON file.
