I am creating a rockon for the Ubiquiti Unifi and i have it mostly working, but for some reason the webui buttion in rockstor is using the wrong port. Any idea’s why it would be doing this? I am going to try to dig though the code and see how it makes this selection. Here is the json file for the rockon
"Ubiquiti Unifi": {
"containers": {
"unifi": {
"image": "jacobalberty/unifi",
"launch_order": 1,
"ports": {
"8080": {
"description": "Port for UAP to inform controller (HTTP redirect for WebUI). Suggested default: 8080",
"host_default": 8080,
"label": "Redirect to WebUI",
"protocol": "tcp",
"ui": true
"8443": {
"description": "Port for WebUI and API. Suggested default: 8443",
"host_default": 8443,
"label": "HTTPS WebUI",
"protocol": "tcp",
"ui": false
"8081": {
"description": "Redirector port for wireless clients. Suggested default: 8081",
"host_default": 8081,
"label": "Redirector for wireless clients",
"protocol": "tcp",
"ui": false
"8082": {
"description": "Redirector port for wired clients. Suggested default: 8082",
"host_default": 8082,
"label": "Redirector for wired clients",
"protocol": "tcp",
"ui": false
"8843": {
"description": "Port for HTTPS portal redirect. Suggested default: 8843",
"host_default": 8843,
"label": "HTTPS portal redirect",
"protocol": "tcp",
"ui": false
"8880": {
"description": "Port for HTTP portal redirect. Suggested default: 8880",
"host_default": 8880,
"label": "HTTP portal redirect",
"protocol": "tcp",
"ui": false
"3478": {
"description": "UDP port used for STUN. Suggested default: 3478",
"host_default": 3478,
"label": "UDP STUN port",
"protocol": "udp",
"ui": false
"volumes": {
"/var/lib/unifi": {
"description": "Choose a Share for Unifi Controller configuration. Eg: create a Share called unifi-config for this purpose alone.",
"label": "Config Storage"
"description": "Unifi Access Point controller",
"more_info": "This is a containerized version of Ubiquiti Network's Unifi Controller.",
"volume_add_support": false,
"ui": {
"slug": ""
"website": "https://hub.docker.com/r/jacobalberty/unifi/",
"version": "1.0"
