After spending some time monitoring the dashboard on Rockstor I’ve found it to be missing some widgets that I think would be helpful.
CPU/Core Temperature graph. To me it is important because of cats and dogs. fur gets caught in cooling fins and needs to be cleaned out every once in a while. lol
SMART Disk Data. I was thinking it could be a red/yellow/green light next to drive ID where when you click the drive ID it shows the SMART Info. Lets you know if a drive is in pre-fail or fail status from SMART.
per Pool Status. This is for Scrub/balance etc. With % finished. While the data is available in Rockstor it took some time to navigate to/find and would be nice to be able to just look at the dashboard and see.
