Hi all,
I had to redo my Rockstor and ended up with a different ip address than what I was using before. I want to keep the same address I was using so I added it with nmcli cmd. So now I want to delete the new one it created and I can not. I delete it with the ip cmd and it is not there if I then do an ip a command it does not show up but as soon as I reboot it comes back.
I have tried with the GUI also but when I click the pencil icon to edit the connection it does not show the IP addresses.
This is just for cleanup as the ip I added works and I’m using it fin.
Thanks.
UPDATE ---- I figured it out. When you do a network add ans select manual it allows you to specify ip so I added the origional ip adder then deleted the one I did not want.
