phillxnet
(Philip Guyton)
March 28, 2016, 6:58pm
22
@suman Tested on a few different systems / configs here and fake serial seems to be functioning as expected.
suman
(suman chakravartula)
March 31, 2016, 5:56am
23
3.8-12.07 is now available!
I made a couple of Rock-on related improvements in this update. Thanks to @pdenhaan for reporting this issue. I’ve also cleared some backlog with Rock-on submissions from @joshi , @bug11 @henfri and @pdenhaan . Great to see these submissions. Please keep them coming! and thank you!
opened 10:04AM - 16 Mar 16 UTC
closed 05:11AM - 31 Mar 16 UTC
It's possible to end up in nasty catch-22s when rock-ons fail.
I was trying to … rig an alternative `btsync-peter` rock-on (the official BTSync is broken at the moment), but made a typo in the port definition. My json file attempted to map port 88888 rather than 8888. Installation obviously fell over because no such port was exposed. So far, so good.
When I corrected my json, Rockstor would not refresh because I wasn't allowed to change the port mappings of installed rock-ons and told me to uninstall first. But there was nothing to uninstall. After all, installation had failed. There seems to be no way offered out of this catch-22.
I only got myself unstuck by firing up `psql` and deleting all the records for my rock-on from the `storageadmin` tables.
The simplest way to fix this would probably be to suppress these port consistency checks when Rock-on installation (as opposed to start-up) has failed. However, there may be more edge cases like this. Given the data duplication between Rockstor's state recorded in `storageadmin` and Docker's own internal state, there is always scope for inconsistencies to arise.
Hello everybody,
is there any overview regarding new features and improvements for the next version 3.8-13?
Any possible release date which can be shared already?
Sorry for asking, but I was not able to find any related information in the forum so far.
Thanks / regards,
Roland
Flyer
(Mirko Arena)
April 8, 2016, 5:28pm
26
If you want to get an idea follow on github to see what’s going on
Rockstor on GitHub
Flyer
suman
April 8, 2016, 11:01pm
27
Hi @glenngould , I’d love to bring more predictability with the timing and scope of releases and we are steadily becoming capable of doing so, thanks to support from our subscribers and customers. It will take some more time and $ to reach that point.
Historically speaking, we released a stable update roughly every 4-6 weeks. This release cycle is the slowest till date, but I am planning to close it out within a week. It may be a lighter update in terms of number of issues closed, but there’s enough good/important stuff that doesn’t justify waiting much longer.
That’s the best non-answer answer I can provide Please stay tuned and thanks for your question!
suman
April 9, 2016, 2:43pm
28
Hello Everyone. 3.8-12.08 is now available!
We’ve closed a few UI related issues that others in our community have kindly reported. Thanks to @ganti_priya and @Flyer for code contributions.
opened 07:55PM - 01 Mar 16 UTC
closed 02:26PM - 09 Apr 16 UTC
bug
When enabling compression the yellow dialog box comes up but does not opt to dis… play below the field instead of above when text will be cut off. This may be a general handling issue that presents from the selection up high.
I suspect extra mount options is the same thing but I don't know if additional text is actually missing from view..
opened 12:09AM - 06 Apr 16 UTC
closed 03:58AM - 07 Apr 16 UTC
In the shares detail view, under the Edit compression Algorithm section, if Subm… it button is clicked with the default text option saying "Don't enable compression", the following error is shown.
opened 07:56PM - 15 Dec 15 UTC
closed 02:41PM - 09 Apr 16 UTC
enhancement
This non-SSL favicon file is accessed:
http://rockstor.com/media/images/ico… /favicon.ico
suman
April 11, 2016, 2:46pm
30
Hi there! 3.8-12.09 is now available. Please test away!
There are two issues fixed in this update. One is a small Rock-on related improvement. The other is an improvement to the way we unmount various resources during pool/share/snapshot deletions.
I’ve been working on adding teaming support (and possibly bonding) which is about 60%, so planning to wrap that up this week. There are a few other important but small(thankfully) issues that are also in the pipeline for this week and hopefully we can all have the stable update towards the end of this week!
opened 01:20PM - 21 Feb 16 UTC
closed 07:50PM - 10 Apr 16 UTC
enhancement
Hello,
currently, RockStor does allow editing and thus adding storage while a r… ock-on is running.
But then, when submitting the changes, an error message pops up telling that this action is only possible when the rock-on is not running.
This is annoying, as this only comes up, after the user has specified all the settings in good hope that it will run.
Proposals:
Editing config should only be possible if rockon is off
OR
Editing config should be possible if rockon is running, but the user should be informed that after the changes a restart is needed. This restart should be offered
Greetings,
Hendrik
opened 06:53PM - 03 Apr 16 UTC
closed 01:45PM - 11 Apr 16 UTC
bug
The current pattern is to check if a mount exists and if not, then umount it. In… rare occasions, it results in mount disappearing right after the check and before umount causing umount_root to fail. Better to just umount and interpret the error. Error code(32) is useless because it's the same for other errors like invalid mount point etc.. So rely on the substring in the error message "not mounted"
suman
April 13, 2016, 4:07pm
32
3.8-12.10 is now available!
We’ve closed to issues, thanks for contributions from @Flyer and @ganti_priya ! you both rock!
First is a bugfix to sorting behaviour on System → Services page and Second is improvement to handlebar templating in Samba export management.
opened 08:49AM - 20 Feb 16 UTC
closed 03:22PM - 13 Apr 16 UTC
bug
After creating a share, when going back to it via the 'edit' button, some -… if not most- of the inputs do not display the correct data. Example: Read Only always stays on yes.
I was on my way to make a pull request for this but it seems to me this page needs more work. I'm happy to do that extra work if we agree it's needed.
There are many duplications in the .jst as follow:
``` handlebars
{{#if sambaShareIdNotNull}}
<input type="text" id="comment" class="form-control" name="comment" value="{{smbShareComment}}" title="Comment string to associate with the new share">
{{else}}
<input type="text" id="comment" class="form-control" name="comment" value="Samba-Export" title="Comment string to associate with the new share">
{{/if}}
which IMHO should be:
``` handlebars
<input type="text" id="comment" class="form-control" name="comment" value="{{smbShareComment}}" title="Comment string to associate with the new share" placeholder="Samba-Export">
And the javascript defines 5 handlebar helpers to render 3 yes/no radio buttons and 2 selects. Couple of bullets for this:
- I guess the yes/no radios should be checkboxes
- Those helpers defeat the purpose of having a templating engine. Why not use a handlebar partial instead ? Especially as the helpers duplicate the code by quite a bit. Each yes/no helper has 4 lines of html. (1 per permutation between `checked` and the option `name` and `value`)
- This is where the original issue comes from; there's a few `this` and scope confusion in the building of the yes/no radios.
opened 09:26PM - 04 Mar 16 UTC
closed 03:57PM - 13 Apr 16 UTC
Minor bug I noticed. I can sort by name but sort by status button exists and doe… s not change anything.
suman
April 15, 2016, 3:49pm
34
Another day, another update… 3.8-12.11 is now available. Please test!
We closed two issues. @Flyer added smtp auth support to our e-mail notification setup as requested by some of you. Second, I fixed a bug in Rock-on profile update. Thanks to @pdenhaan for reporting it and pretty much giving away the fix. We’ve got a great community going, happy friday everybody!
opened 01:52PM - 23 Mar 16 UTC
closed 03:46PM - 15 Apr 16 UTC
It would be great if there was an option to specify a specific username in … Email Alerts vs assuming it is the same as the "From" address. My specific case is that I use SparkPost for transactional emails and they require a username of 'SMTP_Injection' for SMTP connections (this is the same for all SparkPost accounts).
Thanks!
opened 11:26AM - 12 Apr 16 UTC
closed 03:13PM - 15 Apr 16 UTC
When a Rock-on installation has failed, the Update button on the UI (`/home#rock… ons`) fails with the following error message:
The error is correct: the rock-on's state is `install_failed` rather than `available`.
storageadmin=# select * from storageadmin_rockon order by id;
id | name | description | version | state | status | link | website | https | icon | ui | volume_add_support | more_info
1 | BTSync | BitTorrent Sync | 1.0 | install_failed | stopped | | https://www.getsync.com/ | f | | t | t | <h4>Authentication</h4><p>Default username for your BTSync UI is<code>admin</code>and password is<code>password</code></p><h4>Storage</h4><p>You can also assign additional Shares for custom organization of your data.</p>
But obviously there is nothing that can be uninstalled because BTSync failed to install in the first place. I suspect the update code needs to check for `state != "installed"` rather than `state == "available"`.
Manually updating the `storageadmin_rockon` record to `available` state allows the update to proceed successfully.
This may be linked with, but not (I think) identical to, #1124.
suman
April 20, 2016, 4:34am
36
3.8-12.13 is now available!
I merged support for Network Teaming and Bonding that has been under construction for some time. That makes this update into a big one! Thanks to @ganti_priya for UI contributions. I am happy with the design and various teaming profiles and bonding modes are functioning as expected. But I am hoping that everyone in the community that asked for these features will test it thoroughly and report back any issues. In the process of adding Teaming/Bonding support, we’ve also improved how network related dependencies are handled. For example, a nice side effect is that you can now restrict Rockstor management on a designated connection/ip and port.
We also have a new contributor in this update which is always a reason to celebrate. Thanks @ScarabMonkey !
opened 02:18PM - 03 Jan 15 UTC
closed 03:09AM - 20 Apr 16 UTC
Major Feature
I tried to set up bonded networking. There were several issues I ran into.
… NetworkManager conflicts with Rockstor and they both try to use different interface names and overwrite each others setting. I just uninstalled NetworkManager with yum.
Bonded networking adds a file /sys/class/net/bonding_masters which Rockstor tries to enumurate as a network interface and errors out. In system/osi.py network_devices I changed
devices = os.listdir('/sys/class/net')
to
ifpath = '/sys/class/net'
devices = [name for name in os.listdir(ifpath) if os.path.isdir(os.path.join(ifpath, name))]
so it only enumerates directories.
If viewing the interface properties in Rockstor, even if no changes are made and cancel is clicked, Rockstor rewrites the ifcfg file and clobbers the bonding settings
It would be great if Rockstor could fully support bonded networking for either failover or aggregation, but at minimum it should play nicely with a manual setup.
rockstor:master ← ScarabMonkey:advise_nmtui
opened 03:30PM - 15 Apr 16 UTC
Advise the user to use nmtui to fix network configuration at first boot.
