Quick question:
Yesterday at 9:58pm EST I got a communication from the server saying that it couldn’t open sdi.
Looking at my disks I don’t see a sdi, all disks are accounted for, but they are out of sequence. They go from sdh to sdj. I suppose uuid can change, but while running?
[root@mellorockstor ~]# smartctl -A /dev/sdi
smartctl 6.2 2013-07-26 r3841 [x86_64-linux-4.6.0-1.el7.elrepo.x86_64] (local build)
Copyright © 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Smartctl open device: /dev/sdi failed: No such device
[root@mellorockstor ~]# ls /dev/sd?
/dev/sda /dev/sdc /dev/sde /dev/sdg /dev/sdj /dev/sdl
/dev/sdb /dev/sdd /dev/sdf /dev/sdh /dev/sdk
[root@mellorockstor ~]# lsblk -o NAME,SERIAL,SIZE,TRAN,TYPE,FSTYPE,LABEL
NAME SERIAL SIZE TRAN TYPE FSTYPE LABEL
sda JK1105YAKYG9TX 1.8T sata disk btrfs pool
sdb YAK71UHV 1.8T sata disk btrfs pool
sdc JK11B1B9HRP24F 1.8T sata disk btrfs pool
sdd 154856401560 223.6G sata disk
├─sdd1 500M part ext4
├─sdd2 11.8G part swap
└─sdd3 211.3G part btrfs rockstor_rockstor
sde Y485REZTS 1.8T sata disk btrfs pool
sdf YAK6D79V 1.8T sas disk btrfs pool
sdg JK11B1YBKYBTHF 1.8T sas disk btrfs pool
sdh JK1105B8G6Z14X 1.8T sas disk btrfs pool
sdj JK1171YAJSMAKS 1.8T sas disk btrfs pool
sdk JK11B1B9K3ENRF 1.8T sas disk btrfs pool
sdl WD-WCAVY4457087 1.8T sas disk btrfs pool
sr0 K1HEAEA5206 1024M sata rom
Any ideas?
Thanks!
