Error activating Active Directory
When trying to connect to AD, I got the following:
File “/opt/rockstor/src/rockstor/smart_manager/views/active_directory.py”, line 199, in post
smb_config = self._get_config(smbo)
File “/opt/rockstor/src/rockstor/smart_manager/views/base_service.py”, line 40, in _get_config
File “/usr/lib64/python2.7/json/init.py”, line 338, in loads
File “/usr/lib64/python2.7/json/decoder.py”, line 366, in decode
After trying later, it stated that NTP needed to be setup first. After doing that, all is fine.
@IT_Support Welcome to the Rockstor community.
Thanks for the report and glad it worked for you in the end. It does look like we have a usability issue here somewhere so your report will help.
Cheers, and thanks for posting the update.
