Error during upgrade
HI
I’m new to this forum and Rockstor. Been previously using OMV but ran into issues and being not too good at CLI and receiving very little help, thought will give Rockstor a go.
It didn’t go so well, as I had to install 3.8.15 in-order to get pass the errors I was receiving. The new version gave a rest_int+ 0x80/0x80 error. From the forum a suggestion was to try 3.8.15 which worked, but its really annoying and sad that i cant updated on the regular channel even once. I went with the testing channel and the update gave me this error.
            > Traceback (most recent call last):
File “/opt/rockstor/src/rockstor/storageadmin/views/share.py”, line 99, in get_queryset
reverse=reverse)
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/query.py”, line 162, in iter
self._fetch_all()
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/query.py”, line 965, in _fetch_all
self._result_cache = list(self.iterator())
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/query.py”, line 238, in iterator
results = compiler.execute_sql()
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/db/models/sql/compiler.py”, line 840, in execute_sql
cursor.execute(sql, params)
ProgrammingError: column storageadmin_share.pqgroup_rusage does not exist
LINE 1: …n_share".“rusage”, “storageadmin_share”.“eusage”, "storagead…
