Removed all snapshots and all rockons to try to redo it all.
Now I get this when trying to reinstall syncthing:
==> /opt/rockstor/var/log/rockstor.log <==
[13/Nov/2015 16:39:48] DEBUG [storageadmin.views.rockon_helpers:81] Attempted to remove a container(syncthing). out: [’’] err: [‘Error response from daemon: no such id: syncthing’, ‘Error: failed to remove containers: [syncthing]’, ‘’] rc: 1.
[13/Nov/2015 16:39:51] DEBUG [storageadmin.views.rockon_helpers:129] exception while installing the rockon
[13/Nov/2015 16:39:51] ERROR [storageadmin.views.rockon_helpers:130] Error running a command. cmd = [’/usr/bin/docker’, ‘run’, ‘–log-driver=syslog’, ‘-d’, ‘–restart=on-failure:5’, ‘–name’, u’syncthing’, ‘-v’, u’/mnt2/syncthing:/home/syncthing/Sync’, ‘-v’, u’/mnt2/syncthing:/home/syncthing/.config/syncthing’, ‘-p’, u’22000:22000/tcp’, ‘-p’, u’8384:8384/tcp’, ‘-p’, u’21025:21025/udp’, u’istepanov/syncthing’]. rc = 1. stdout = [’’]. stderr = [‘Error response from daemon: stat /mnt2/rockons-ssd/btrfs/subvolumes/2a21accd3df962e4327bc4238363e790d7c38e4459fd311792a62d0710c88a9a: no such file or directory’, ‘’]
File “/opt/rockstor/src/rockstor/storageadmin/views/rockon_helpers.py”, line 127, in install
globals()’%s_install’ % rockon.name.lower()
File “/opt/rockstor/src/rockstor/storageadmin/views/rockon_helpers.py”, line 236, in syncthing_install
return generic_install(rockon)
File “/opt/rockstor/src/rockstor/storageadmin/views/rockon_helpers.py”, line 191, in generic_install
run_command(cmd)
File “/opt/rockstor/src/rockstor/system/osi.py”, line 84, in run_command
CommandException: Error running a command. cmd = [’/usr/bin/docker’, ‘run’, ‘–log-driver=syslog’, ‘-d’, ‘–restart=on-failure:5’, ‘–name’, u’syncthing’, ‘-v’, u’/mnt2/syncthing:/home/syncthing/Sync’, ‘-v’, u’/mnt2/syncthing:/home/syncthing/.config/syncthing’, ‘-p’, u’22000:22000/tcp’, ‘-p’, u’8384:8384/tcp’, ‘-p’, u’21025:21025/udp’, u’istepanov/syncthing’]. rc = 1. stdout = [’’]. stderr = [‘Error response from daemon: stat /mnt2/rockons-ssd/btrfs/subvolumes/2a21accd3df962e4327bc4238363e790d7c38e4459fd311792a62d0710c88a9a: no such file or directory’, ‘’]
Same with All other rockons that had a snapshot
