After upgrading to 3.8.3 I am still seeing this error?
Thoughts? @suman
Is there any output in the logs? The logs are found at /opt/rockstor/var/log/rockstor.log
Yes here is the errors
[18/Jul/2015 17:10:37] ERROR [storageadmin.util:38] request path: /api/pools/pool01/scrub method: GET data: <QueryDict: {}>
[18/Jul/2015 17:10:37] ERROR [storageadmin.util:39] exception: invalid literal for int() with base 10: 'afterâ
File â/opt/rockstor/src/rockstor/rest_framework_custom/generic_view.pyâ, line 40, in _handle_exception
File â/opt/rockstor/src/rockstor/storageadmin/views/pool_scrub.pyâ, line 46, in get_queryset
self._scrub_status(pool, disk)
File â/opt/rockstor/eggs/Django-1.6.2-py2.7.egg/django/db/transaction.pyâ, line 399, in inner
return func(*args, **kwargs)
File â/opt/rockstor/src/rockstor/storageadmin/views/pool_scrub.pyâ, line 56, in _scrub_status
cur_status = scrub_status(pool, disk.name)
File â/opt/rockstor/src/rockstor/fs/btrfs.pyâ, line 627, in scrub_status
stats[âdurationâ] = int(out[1].split()[-2])
ValueError: invalid literal for int() with base 10: âafterâ
btrfs scrub status /mnt2/pool01
scrub status for cdc962b5-f6f6-45b4-bfc0-17316b3c1d7f
scrub started at Mon Jul 13 22:03:23 2015 and finished after 01:03:48
total bytes scrubbed: 1.30TiB with 1632 errors
error details: read=4 csum=1628
corrected errors: 1632, uncorrectable errors: 0, unverified errors: 0
Returns this.
I kicked off another scrub as from looking at the code and the error I figured it was not handling what was being returned and presto fixed.
So there is a bug.
Can this please be looked at and addressed.
Thanks
Chris
@sirhcjw and @gkadillak well done people. I have opened a github issue recording this info and given itâs prominence this should receive a high priority, however I think this one is in @suman only territory for the time being so it may be a little while as he is currently out and about promoting Rockstor via conference appearances.
Nice find.
I have actually seen the same error.
In my case it established itself, while I was running a scrub, and asked the system to shut down.
It told me it did a gracefull shutdown.
When I restarted the system, I got the exact same error as shown in the original message, when selecting the pool that was being scrubâed.
I initiated a new scrub from the command-line âbtrfs scrub start /mnt2/**poolâ, went to the pool in the web -interface, and the error was gone when clicking it.
So it would seem the system did not do a completely gracefull shutdown.
@KarstenV I donât think this error indicates a non graceful shutdown as it seems to be a bug in the way the UI is interpreting the state of the btrfs scrub; ie in certain situations it errors when trying to interpret perfectly sane responses from the btrfs subsystem. It should be taken in hand soon via the referenced issue.
OK.
Just something I experienced.
I would think it would be wise for the system to check for running scrubs / balances, and ending them, before shutting down. I would guess that this is allready implemented, but my experience showed me otherwise.
But thank you for the answer
@KarstenV Iâm afraid I am not yet up on this part of Rockstor so donât really know; it was just the impression I got from the log entry. It might be that a scrub, once initiated, is continued / restarted if it fails to complete due to reboot. I expect @suman can clear this up once he get done on other outstanding bits and bobs. Sorry not to be of any more help / reassurance on this; and given the error is in reading the scrub state we may have a chicken and egg problem here. Thanks for reporting you findings thus far.
Well there is definately something wrong.
The scrub I initiated last evening ended this morning. The results were like this:
As soon as the scrub ended I tried to click the relevant pool in the web-interface and got the error:
I will add that during the scrub, I was able to click on my pool, and see the status of it without error messages.
So there is definately something thats not right
I have managed to get access to clicking my pool again.
I was trying out some commands i saw in a video regarding maintenance on btrfs.
The command was âbtrfs scrub start -B -d /dev/sdxâ.
The -B tells the btrfs scrub, to not run in the background. Then you can exit out by doing Ctrl-c.
After having run a partial scrub and exiting out this way, the pool was accesible in the web interface again.
This is not a fix to the original problem, but it does make it possible to access the pool, and add/remove disks / do other maintenance.
Hope other peoble are able to make their pools accesible again.
@KarstenV Thatâs an excellent find, thanks for submitting it. I have quoted your findings in the ongoing github #issue752 to assist in the fix and collect triggers / info / workarounds. Looks like at least one cause of this error is pretty much known now. This is a great help. We now have at least 2 issues open that may related to the root cause of this so itâs going to be gratifying to have this one done and dusted. @suman has recently confirmed an extension to the usual release candidate testing period going forward and I believe there are plans to further extend the automated test coverage so hopefully show stoppers such as this wont be as common. Hereâs hoping.
Error!
Looks more like the wrong type of variable is used here: perhaps int() instead of float()
No idea about the coding and where to find it but I think thatâs the problem.
Looking in the code at Github, I notice you mix the size = models.IntegerField() and size = models.BigIntegerField(default=0)
Also If you want to accept null values with BooleanField,
use NullBooleanField instead. offline = models.BooleanField(default=False)
Hope this helps.
Just want to update that the fix is rolled out in 3.8-4 update. Thanks for all your contributions.
@suman Thanks, your welcome, I will test it
