When I try to install Sickbeard, RageBeard or Sonarr, I follow the wizard without any error (a separate share for config and downloads for every rockon). When I click submit it just goes to the Installed tab but without installing it. If I go to the All tab I can see the rockin saying that there was an error with the installation and to check /opt/rockstor/var/log for clues. I tried restarting the rockon service, rebooting, trying to install them without any other rockon running and repeating the same steps on other browsers (to make sure it wasn’t a browser issue)
This is what I found in the file. What can I do to solve this?
[25/Nov/2017 19:00:13] ERROR [storageadmin.middleware:32] Exception occured while processing a request. Path: /api/commands/refresh-share-state method: POST
[25/Nov/2017 19:00:13] ERROR [storageadmin.middleware:33] need more than 2 values to unpack
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/core/handlers/base.py”, line 132, in get_response
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/views/decorators/csrf.py”, line 58, in wrapped_view
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/views/generic/base.py”, line 71, in view
File “/opt/rockstor/eggs/djangorestframework-3.1.1-py2.7.egg/rest_framework/views.py”, line 452, in dispatch
File “/opt/rockstor/eggs/djangorestframework-3.1.1-py2.7.egg/rest_framework/views.py”, line 449, in dispatch
return func(*args, **kwargs)
File “/opt/rockstor/src/rockstor/storageadmin/views/command.py”, line 318, in post
import_shares(p, request)
File “/opt/rockstor/src/rockstor/storageadmin/views/share_helpers.py”, line 83, in import_shares
volume_usage(pool, share.qgroup, share.pqgroup)
ValueError: need more than 2 values to unpack
[25/Nov/2017 19:00:26] ERROR [storageadmin.views.network:85] Unknown ctype: bridge config: {}
